mass flow rate at the out let
Old   January 31, 2008, 20:03
Default mass flow rate at the out let
cfd fanatic
Hi
How can i calculate mass flow rate at the out let of my tunnel for unsteady flow. I need to specify mass flow rate at the out let of my tunnel for unsteady flow. Thank you very much you are lovely people.
Old   February 1, 2008, 00:53
Default Re: mass flow rate at the out let
KK
one way that i can suggest, in cfx-post, go to function calculator then select the specific boundary location or (whatever location you want...e.g. plane) from the drop-down menu for location and choose the option to calculate mass flow rate for the specific fluid.
But this option will require the result file or transient result file to be imported in CFX-post. If you want to monitor at every time step during simulation then you can think about creating an CEL expression to calculate it for you. I have not used CEL so far so may be other experienced user can suggest itin a better way.
But one question? if you want to specify mass flow rate at outlet, why do you want to calculate it?
Old   February 1, 2008, 05:58
martins
you can monitor the mass flow rate during the run by creating a new monitor in the solver manager and select P-mass boundary flow on outlet as plot variable
Old   February 1, 2008, 16:58
CFD fanatic
Hi KK thanks for your answer. I want to use periodic boundary condition for my case. For that i need to specify mass flow rate at the outlet of my duct to drive the flow.
Martins thank you for answer. Another question, what is P-mass?
You are such a lovely people. I love you all so much.
CFD fanatic
Old   February 4, 2008, 13:37
CycLone
P-mass = Mass conservation equation formulated as a function of Pressure.
Old   February 4, 2008, 17:06
cfd fanatic
Hi cyclone can you give me expression for it. I am using periodic boundary conditions. I love you all so much especially you cyclone.
Particle Injection Mass Flow Rate and Position leonozx FLUENT 3 March 9, 2018 09:58
CFX turbo - Mass flow rate Vashishth Patel CFX 7 April 3, 2014 20:33
Mass flow rate at the outlet tejasvikrishna FLUENT 2 May 25, 2013 02:42
negative global mass flow rate Gimli FLUENT 0 April 21, 2006 07:17
mass flow rate error Masood FLUENT 0 May 22, 2005 00:32
