Boundary condition
Old   February 5, 2008, 16:03
Default Boundary condition
bltu
How can I change boundary condition type during a transient run in CFX? For example, for t smaller than a; I want to set pressure outlet, and for t greater than a; I want to set wall condition. Such control can be realized in CFX?
Thanks for your help.
Old   February 5, 2008, 16:11
Default Re: Boundary condition
Rogerio Fernandes Brito
Yes, itŽs possible. YouŽll make two simulations and change these parameters manually. After you do the first one, on the second, youŽll use de file.res as an initial condition on CFX-Solver.
Old   February 5, 2008, 16:18
Yes, itŽs possible. YouŽll make two simulations and change these parameters manually. After you do the first one, on the second, youŽll use the "name_of_file.res" file as an initial condition file on CFX-Solver.
Old   February 5, 2008, 16:25
bltu
Thanks. But, how about the post-processing. I mean, result file time step counter will continue from zero or follow the last one after the second run.
Old   February 5, 2008, 17:15
You must change the total time and the Start (or initial) time on the second part of your simulation! On the second simulation, cfx-v5.6 will record all the data from 0 [s] up to your total time.
Domain Imbalance HMR CFX 5 October 10, 2016 05:57
Boundary Conditions Thomas P. Abraham Main CFD Forum 20 July 7, 2013 05:05
Setting outlet Pressure boundary condition using CAFFA code Mukund Pondkule Main CFD Forum 0 March 16, 2011 03:23
How exactly the "pressure outlet" bdry condition compute properties on the boundary? yating9901 FLUENT 3 June 28, 2010 12:26
How to set boundary condition in Fluent for the fo Peiyong FLUENT 1 November 10, 2006 11:44
