A problem with blocks in Icem
Old   February 13, 2008, 05:31
Default A problem with blocks in Icem
Janne
Hello
I'm a beginner with Icem, im currently using it in my BSc thesis. I've come across a problem I can't solve. Please look at this image: http://img85.imageshack.us/my.php?image=needhelpxr7.jpg
You see how the lines from block 1 bends down to fit into block 2? Like Block 2 is the master and the block 1 is the slave. I've adjusted the number of nodes to 4 in the premesh-params on the vertical edge of block 2(the one marked with edge in pic). But I want it to automatically adjust itself the block 1 instead, so block 1 becomes master and block 2 slave. Is there such a feature in Icem? Would appreciate it much if anyone could explain how I can accomplish this!
Best regards from Sweden
Old   February 14, 2008, 07:59
Default Re: A problem with blocks in Icem
Felix
Hello Janne,
I cannot see your image (imageshack is not accessible here at work) but many problems I've encountered with ICEM Hexa are related to bad associations of edges/points. The first thing to do would be to check these.
I don't know if this helps but it's the best I can say without looking at your specific problem.
Regards,
Felix
Old   February 21, 2008, 08:37
Samuel
Can you show me your geometry section as whole....let me see whether i can sort it out. Sam
ICEM - strange linking problem RodriguezFatz ANSYS Meshing & Geometry 3 October 25, 2011 03:25
[ICEM] Problem with volume mesh in ICEM CFD kolapoasafa ANSYS Meshing & Geometry 2 September 16, 2011 03:54
Icem 12.1 - distance problem sys999 ANSYS 2 January 20, 2011 07:54
Region Problem with ansys 12 icem mesh for cfx compizer CFX 0 May 5, 2010 03:02
Problem exporting big meshes from ICEM to Fire Emil CFX 0 October 10, 2008 13:06
