Non reflective boundary conditions
Like Tree4Likes
  • 2 Post By kasim
  • 2 Post By kasim
Old   February 15, 2008, 04:07
Default Non reflective boundary conditions
KK
Could some one please explain what the purpose/concept/benefit/use of 'Non reflective boundary conditions'(beta function in CFX-11) is?
I am asking this in context of my another question posted at http://www.cfd-online.com/Forum/cfx.cgi?read=24989
How would it help to maintain the flow direction outward at some outlet?
Thank you so much, KK
Old   February 15, 2008, 09:20
Default Re: Non reflective boundary conditions
kasim
Hi KK
Non-reflective boundary condition prevent the pressure fluctutaions to reflect back in your CFD domain. It helps to stabilise your numerical solution.
Kasim
emonome and rajibroy like this.
Old   February 15, 2008, 11:57
KK
Thank you very much Kasim
As opening type boundary conditions are supposed to make Large Eddy Simulations unstable because eddies are recirculated at the boundary, will NON-reflective boundary condition (opening) might help to make the LES simulation stable?
May be my question is not an appropriate one, I am new in CFD.
Thank you so much again, KK.
Old   February 16, 2008, 09:11
kasim
If you have set pressure at the outlet, pressure fluctuations can reach the outlet and de-stabilise the soilution by reflecting back in domain. In that case one should use non-reflective BC. I would suggest that you dont use Opening with non-reflective boundary condition for final solution. You can keep non-reflective BC but change your opening to Outlet once your solution has gained stability.
Kasim
mesh file for flow over a circular cylinder Ardalan Main CFD Forum 7 December 15, 2020 13:06
Domain Imbalance HMR CFX 5 October 10, 2016 05:57
Impinging Jet Boundary Conditions Anindya Main CFD Forum 25 February 27, 2016 12:58
Proper Pressure Boundary Conditions for Buoyant Flow mchurchf OpenFOAM 0 March 25, 2010 12:16
reflective boundary conditions on generalized coor buaalzr Main CFD Forum 3 January 2, 2008 12:43
