Non-dimensional timestep
Old   February 21, 2008, 08:30
Default Non-dimensional timestep
Farid
Hi, can anybody tell me how the non dimensional timestep is calculated? What does it mean by non dimensional timestep of delt=0.004 or else?
Old   February 21, 2008, 17:48
Default Re: Non-dimensional timestep
Where do you get a non-dimensional timestep? CFX uses dimensional timesteps.
Old   February 22, 2008, 03:45
Farid
Hi Glenn,
Thanks.
I know that Cfx uses dimensional timesteps. But, from some literature, I found that they used non dimensional timesteps and I wanna compare my used timesteps in cfx(dimensional) with their non dimensional timesteps. Thats why I wannna convert this dimensional timesteps to non dimensional timesteps.
Old   February 22, 2008, 11:56
andy20
The 'non-dimensionalisation' of a problem, and hence the calculation of a non-dimensional timestep is 100% problem dependent. There is no general rule.
It might be related to (typical length)/(typical speed), but it might also be based on a diffusion timescale, or a number of other possibilities.
You will need to look at the literature you are interested in and see if that describes the choice of timestep used by the authors. If it does not, then you may have to contact the authors directly.
So, unfortunately we cannot give you an answer.
Good luck, Andy
Old   February 24, 2008, 17:16
In addition to what Andy said, you can always convert the dimensional timestep reported by CFX to a non-dimensional timestep simply by applying the non-dimensionalisation for the time variable. Most non-dimensional schemes generate some form of reference time, then the non-dimensional timestep is simply dimensional timestep/reference time.
Restart 2-way FSI with different timestep? Lance CFX 10 April 17, 2013 00:37
Adequate timestep selection for multidomain problem gerardosrez CFX 6 November 28, 2010 17:50
Timestep study ijk CFX 6 April 9, 2010 07:38
interTrackFoam timestep virginie_e OpenFOAM Running, Solving & CFD 4 April 6, 2009 05:02
Use of Timestep in obtaining solution. hagupta CFX 7 February 28, 2006 13:14
