Y plus in fluid fluid interface
Old   February 29, 2008, 08:18
Default Y plus in fluid fluid interface
Subha
Hai All,
I am doing simulation of a cooling fan with CHT model. In my mesh, I have a y plus value less than 1 for those close to the solid boundaries. I have divided the fluid domain in varoius domains for simplicity. At the fluid fluid interface, I have y plus values greater than 1. And one of the interface close to my fan but does not toouch it. Does it really have any effect on my simulation?
I guess not, since there is no solid boundary at this interface.
Thank you for your replies.
Regards,
Subha.
Old   March 1, 2008, 09:43
Default Re: Y plus in fluid fluid interface
Hekler
this should be fine
Old   March 2, 2008, 07:48
Default Re: Y plus in fluid fluid interface *NM*
Old   March 4, 2008, 08:29
Santosh
It is necessary to maintain a good values of Y plus even for Fluid Fluid interface if you want simulate accurately.
Old   March 4, 2008, 08:56
andy20
Why??? What is your logic?
Checks on Y+ should be used to ensure turbulent wall functions will work accurately at no-slip walls. In addition, when using low-Reynolds number turbulence models the value of Y+ is used to ensure boundary layers at no-slip walls are resolved. You can read the theory related to this in the CFX help system.
At a fluid-fluid interface there is no wall, and no boundary layer! Therefore the value of y+ is surely irrelevant.
What, therefore, makes you think y+ is important at a fluid-fluid interface?
Boundary conditions at Fluid Solid interface (CHT) michelle CFX 1 April 21, 2008 04:06
how to use fluid fluid interface Beno CFX 0 July 13, 2005 14:08
BC at the interface of the fluid and solid manohar Siemens 3 April 8, 2005 11:34
access to variables at interface of porous media? Mazyar FLUENT 0 October 10, 2003 14:59
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 09:11
