checking the number of nodes
Old   March 4, 2008, 16:19
Default checking the number of nodes
thiagobaixo
Hello people !
I would like to kown how, in a especific way, we can get the number of nodes in the bondary layer.
I´m simulating a flow around a ressonate pipe. The values that CFX Post to respect yplus is very high. For example the results of this variable is something like 10^6, when i need to get for yplus, yplus < 200 (i´m using SST model with automatic function wall).
I´m using the ICEM CFD to generate the mesh, and for refining the mesh, i´m using prism layer, in this case i only input a value for the numbers of layer.
I need to resolve the bondary layer, but i´m with difficulties about this.
thanks for anyone, who can get help me !
regards !
Old   March 4, 2008, 22:53
Default Re: checking the number of nodes
Omer
I can tell you this...
In CFX Post draw a line through your domain so that it goes through your boundary layer. Plot velocity through that line and export the result on the nodes. Now try to see where your boundary layer is, by using the old .99 rule of mean flow velocity.Now count the nodes.
There must be a better way, but that is all I know.
Regards
Problems in compiling paraview in Suse 10.3 platform chiven OpenFOAM Installation 3 December 1, 2009 07:21
[blockMesh] BlockMeshmergePatchPairs hjasak OpenFOAM Meshing & Mesh Conversion 11 August 15, 2008 07:36
Interpolation (Number of mapped nodes) Sam CFX 3 January 6, 2008 19:51
Number of nodes on block. Felix CFX 0 October 24, 2007 22:26
CFX4.3 -build analysis form Chie Min CFX 5 July 12, 2001 23:19
