March 7, 2008, 04:35 |
Convergence problem in mixing chamber
Hello everyone.
I have a convergence problem in a mixing chamber. flow is injected into chamber from a big inlet port and 4 small inlet ports.(Inlet B.C. = 40, 30, 20, 10 bar) each of injected flows are merged in mixing chamber and discharged into a discharging nozzle.(Outlet B.C. = 1atm) In case of low pressure inlet condition(10bar), simulation was well converged with any mesh size and turbulence models. In case of high pressure inlet condition(40,30bar), however, continuity, k and epsilon are diverged.(different mesh size and turbulence models) Although I changed pressure inlet condition to mass flow rate inlet condition, simulation result was diverged. How can i solve this problem? Thank you in advance. |
Force can not converge | colopolo | CFX | 13 | October 4, 2011 22:03 |
convergence problem | commonyue | Main CFD Forum | 1 | December 1, 2009 03:54 |
Submerged fin, Convergence problem | supermouniette | FLUENT | 10 | July 6, 2009 10:47 |
Convergence of CFX field in FSI analysis | nasdak | CFX | 2 | June 29, 2009 01:17 |
convergence problem in comsol | anderson | COMSOL | 0 | February 24, 2008 16:54 |
