Coupled Heat Transfer Simulation
Old   March 5, 2008, 03:18
Default Coupled Heat Transfer Simulation
asder
Is it possible to simulate a pin fin array problem with CFX (Fluid Domain-CFD Solution) and ANSYS (Solid Domain-Thermal Solution)? Could you give me hints about such simulation and what ANSYS software is required?
Old   March 5, 2008, 04:17
Default Re: Coupled Heat Transfer Simulation
selim
As I understand you want to simulate convective and conduction heat transfer coupled. It is called conjugate heat transfer There is a tutorial available in CFX. Use help search to find
-- Selim
Old   March 5, 2008, 06:25
asder
Yes, I have seen this example. But I would like to do also a thermal analysis on the solid domain which requires a FE analysis coupled with CFD analysis. The solid domain is a pin fin metal block which heated only at some locations so that I need to solve also heat conduction within the solid.
Old   March 5, 2008, 07:00
selim
Ok But heat conjugate property automatically solves the conduction and convection.You have to just define your solid and fluid doamins and appropriate BC on the solid and fluid , It solves this coupled problem and automatically satisfies the interface for you --- Selim
Old   March 7, 2008, 13:51
Craig Hildreth
CFX will do this. Just set up solid domains.
Simulation of a single bubble with a VOF-method Suzzn CFX 21 January 29, 2018 00:58
Help with conjugate heat transfer and coupled boundary condition ravitejakatragadda FLUENT 1 March 12, 2011 07:31
MRF and Heat transfer calculation Susan YU FLUENT 0 June 2, 2010 08:46
Heat Transfer boundary conditions for engine coolant flow simulation rajuks Main CFD Forum 0 February 15, 2010 09:04
how to model heat transfer for the coupled wall jing113cn FLUENT 0 June 22, 2009 03:56
