March 18, 2008, 16:59 |
Reynolds Number Check?
Let's say I have a problem that I believe is laminar in nature. Is there a way to check the OUT file or set up a monitor to confirm that the Reynolds number was indeed in the laminar regime after the problem runs? Thanks.
March 19, 2008, 15:20 |
Re: Reynolds Number Check?
The solver will output a Reynolds number (search for it in the OUT file), but it may not be the one you are looking for. Since the solver doesn't know what your relevant length or velocity scale are, it uses the cube root of the volume as a reference lenght (or the maximum dimension of the bounding box, I can remember for sure) and something like the RMS average velocity as a length scale.
To be certain, you should calculate your Reynolds number in Post using the appropriate velocity and length scales. Note that if your Reynolds number is large and the flow is turbulent, you'll probably have difficulty converging due to the instability, although if your mesh is coarse the numerical diffusion may damp these out. So this can also be a good indicator. -CycLone |
[mesh manipulation] Mesh Refinement | Luiz Eduardo Bittencourt Sampaio (Sampaio) | OpenFOAM Meshing & Mesh Conversion | 42 | January 8, 2017 12:55 |
Low Reynolds Number k-epsilon formulation CFX 10.0 | Chris | CFX | 4 | December 7, 2009 23:51 |
Reynolds Number | Matt | CFX | 0 | February 25, 2009 05:40 |
Unaligned accesses on IA64 | andre | OpenFOAM | 5 | June 23, 2008 10:37 |
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues | michele | OpenFOAM Meshing & Mesh Conversion | 2 | July 15, 2005 04:15 |
