March 19, 2008, 07:47 |
Negative pressure!
I am trying to model a horizontal cylindrical device with one inlet and 2 outlets (gas, liquid). The inlet fluids are air (continuous) and water (dispersed).The total pressure is 4 bar. The boundary conditions regarding pressure are 1)gas outlet- static pressure= 0 Pa 2)liquid outlet-static pressure= 12000 Pa 3) inlet pressure is governed by flowrates of air and water
Initially i had problems with backflow. Some of the guys here adviced me to extend geometry, many thanks to them, it works! I have extended the geometry of the outlets in order to avoid backflow or re-circulation and I used the static pressure at the liquid outlet as 5000 Pa. to enable some hold up. Now , I dont get any backflow , but I still get negative pressure as in my previous cases. In CFX-post it seems like there is no interaction between water and air. It seems like only water is forced and not air, this is not true! Please advice. Thanks, Neel |
Pressure BC for combustion chamber | Giuki | FLUENT | 1 | July 19, 2011 11:35 |
seeking for help about a room with negative pressure | mengyue1 | FLUENT | 0 | November 26, 2009 06:40 |
High pressure in rhopSonicFoam results in negative pressure | shangzung | OpenFOAM | 0 | November 5, 2009 03:24 |
negative pressure in cfx | flar.t | CFX | 1 | December 18, 2006 23:20 |
negative pressure | mAx | FLUENT | 0 | January 25, 2006 14:31 |
