Where is gone my mesh?
Old   April 18, 2008, 15:47
Default Where is gone my mesh?
Young
Hi....Colleagues...
I made a mesh for room model.
it has nearly 9321195 elements.
I tend to open it using "Creat CFD simulation with mesh"
Although each elementary number like F.01.23 show in the tree veiw, there are no element in graphic window...
Where is my mesh gone?
Thank you for your concerns
Old   April 18, 2008, 15:51
Default Re: Where is gone my mesh?
Sally
Look carefull on your screen, it has probably been miniaturized beyond belief. Toggle your mouse and when you see a small dot flashing, zoom in on it.
Old   April 18, 2008, 16:12
Young
Thanks Sally,
I do everything you mentioned, however, I can't find anything..
I don't know what is wrong with it....there is no error message....
anyway..thanks.
Old   April 20, 2008, 18:32
10 million elements!!?? That is a big mesh. Are you sure you need a mesh that big? If you do then there is no way you will run it in 32 bit, you will need 64 bit and it is going to be very slow (both the setup and simulation).
Old   April 21, 2008, 16:39
Young
Thanks Glenn,
Actually, it is a radiant floor heating model.
As you know, it has a tiny radius (5mm) but extra long (nearly 10m) tube for water circulation.
When I reduce the mesh size to avoid to meet error, the number of total elements are up to nearly 10 MI.
Now I looking for a method to reduce the number of mesh.
Thanks
Old   April 21, 2008, 18:58
You will then need to be careful to refine the mesh in the region of the thin tube and coarsen out in the main region.
Also use a swept mesh around the tube so you can use high aspect ratio elements.
Old   April 21, 2008, 23:46
Young
Thanks Glenn,
[ICEM] surface mesh merging problem everest ANSYS Meshing & Geometry 44 April 14, 2016 06:41
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Meshing & Mesh Conversion 2 March 27, 2011 21:11
Meshing aifoil in ICEM student123a ANSYS Meshing & Geometry 13 December 8, 2010 10:40
mesh missing after export in gambit morteza08 ANSYS Meshing & Geometry 1 July 26, 2010 01:10
2d irregular grid Remy Main CFD Forum 1 December 22, 2008 04:49
