April 23, 2008, 13:14 |
[volume mesh]errors -.-
Hi all,
I have continuously met the error in volume mesh processing as follows; =========================================== Error The volume mesher is unable to build an element from the current face, and cannot continue. 1) Check the quality of the surface mesh in this vicinity, This can be achieved by viewing the Mesh before Inflation or the Inflated Front. ==> How do I check the quality of mesh? 2) Check that the mesh spacing is less than the distance between neighbouring CAD faces. ==> How do I know neighbouring CAD faces? 3) If inflation is being used, try increasing the Minimum Internal Angle. With extended inflation layers and curved surfaces an angle of > 15 degrees may be appropriate. ==> I put the 30 Degrees for the Minimum Internal angle but it has still error in different element. 4) Try reducing the mesh spacing in this area by adding appropriate mesh controls and remeshing. ==> How Do I control the mesh? F3 coordinates: [ 1.9672E+02, 2.8422E-14, 3.2940E+02] [ 1.9773E+02, 2.8422E-14, 3.2940E+02] [ 1.9773E+02, 5.1962E-01, 3.2970E+02] Current mesh spacing = 9.6956D-01 ++++++++++++++++++++++++++++++++++++++++++++++++++ ++++++++++++++ there are a lot of question.... I hope your kind responses. thanks |
