ICEM CFD - preset quality criteria
Old   May 6, 2008, 23:36
Default ICEM CFD - preset quality criteria
JSM
Dear all,
I am facing problems in meshing the complex geometry. I have the following doubts. Please clarify this.
1. To preset the quality criteria before doing the meshing like sqewness <0.8 and min angle > 15 deg. etc. Is it possible to set the quality criteria before starting the meshing?
2. To set the maximum mesh elements before doing mesh?
3. Kindly give some general guidelines and documents to repair mesh manually for non-manifold elements and surface orientation error etc. Is it any tutorial available to practice repair mesh option?
Thanks in advance
With regards, JSM
Old   May 7, 2008, 07:28
Default Re: ICEM CFD - preset quality criteria
Andrew
You use the split vertex tool to fix non-manifold vertices. The help file explains how. Surface orientation errors indicate overlapping elements. The only way I know to fix these is to remesh the elements.
Old   May 7, 2008, 23:36
JSM
Hi Andrew,
Thanks for your reply. Could you give me the tutorial file name. It is more helpful to me.
Is it possible to set the mesh quality what we want before starting the meshing?
Thanks with regards, JSM
[ICEM] Mesh quality criteria in ICEM Chander ANSYS Meshing & Geometry 13 September 5, 2017 08:52
Learn ANSYS ICEM CFD easy_astronaut ANSYS 2 December 15, 2013 15:34
icem cfd ai environment 11.0, laptop keyboard problem, linux pertupd Hardware 3 October 3, 2011 08:27
ICEM CFD use for ? Vu Trinh Tuan CFX 14 April 11, 2011 18:38
ICEM CFD Modules Boris FLUENT 1 March 12, 2004 14:37
