Temp as Celcius in legend
Like Tree8Likes
  • 1 Post By andy2o
  • 7 Post By Andrew
Old   May 12, 2008, 08:47
Default Temp as Celcius in legend
John
Is it possible to get CFX-Post to show a temperature legend in Celcius rather than Kelvin?
I find it hard to believe this is not possible but can't for the life of me find an option to do it.
Thanks.
John.
Old   May 12, 2008, 14:56
Default Re: Temp as Celcius in legend
andy2o
There may be a better way, but as no-one else has replied yet here's one idea:
For basic temperature plots I managed to get deg C by going to 'Options', then selecting the 'Units' menu, then selecting 'Custom' then changing the units of temperature only to [C]. This worked OK for plotting the basic temperature field. Two slight problems with this though:
1) This will alter the default behaviour of other parts of CFX, so you may want to swap it back after printing the plot.
2) It worked for plotting the temperature field. But when I plotted a variable which had units of [K] which I had computed using a complicated CEL expression I still got units of [K], not [C].
Good luck, andy
(I'd like to see a 'convert_units' function added to the CEL language ....)
hfs1995 likes this.
Old   May 16, 2008, 11:29
Andrew
Go to Variables > Solution > Temperature and select the desired units. Then everywhere you use that value in post it is converted to those units. However if you perform a calculation using CEL or a table, the result will be in absolute units [K] or [R].
CFB+wall BC for solid vel and gran temp Umesh FLUENT 2 September 10, 2013 17:21
CFX post legend modification mactech001 CFX 3 December 25, 2011 22:12
How to find Bulk temp?? gandesk FLUENT 0 December 2, 2010 10:40
REAL GAS UDF brian FLUENT 6 September 11, 2006 08:23
nonsense Temp. values bogesz CFX 4 February 2, 2004 07:29
