batch mode - parallel run
Old   March 28, 2011, 23:15
Default batch mode - parallel run
turbotel is on a distinguished road
generally in I solve the problem on my server machine.
1 master node & 2 compute node, windows HPC server 2008: OS.
i use "HP MPC local parallel" run mode for solving.
this is my script file for batch mode:
#! perl -w
use strict;
my $solver = "C:/Progra~1/AnsysI~1/v130/CFX/bin/cfx5solve.exe";
die "Unable to find program '$solver'" if ! -f $solver;
system "$solver -def 95000rpm_wo2.def -ini 62000rpm_wo2_002.res -par-local \"TRDCFDMASTER01*14\" -start-method \"MPICH Local Parallel"
and i'm getting the below error message:
unknown command line option TRDCFDMASTER01*14
TRDCFDMASTER01 - is my master node's name.
I've tried with following changes(red font)
#! perl -w
use strict;
system "$solver -def 95000rpm_wo2.def -ini 62000rpm_wo2_002.res -par-dist \"TRDCFDMASTER01*14\" -start-method \"MPICH Local Parallel"
and got the following error.
E:\Projects\CFD\W408\new>perl batch.pl
An error has occurred in cfx5solve:
The solver executable C:\Program Files\ANSYS
Inc\v130\CFX\bin\winnt-amd64\solver-mpich.exe could not be found, or is not
readable.
pls somebody help.
turbotel is offline   Reply With Quote
Old   March 29, 2011, 16:42
sam13
Shafiul is on a distinguished road
Not sure, could be a syntax error. Try this one:
$solver -def 95000rpm_wo2.def -ini 62000rpm_wo2_002.res -par-local "TRDCFDMASTER01*14" -start-method "MPICH Local Parallel"
Shafiul is offline   Reply With Quote
Old   March 29, 2011, 16:53
stumpy is on a distinguished road
See "cfx5solve -help". For the first error -par-local doesn't have a list of hosts after it, you should combine this with -part to set the number of partitions. For the second error "MPICH Local Parallel" is not a valid start method - try one of the options listed in the Solver Manager when starting a local parallel job.
stumpy is offline   Reply With Quote
Working directory via command line Luiz CFX 4 March 6, 2011 20:02
Error within a batch run Jia Li CFX 7 July 29, 2010 18:54
parallel mode failure in 3ddp but not in 2ddp ak6g08 FLUENT 1 September 22, 2009 06:56
Run in parallel a 2mesh case cosimobianchini OpenFOAM Running, Solving & CFD 2 January 11, 2007 06:33
run f;uent job in batch mode? jx FLUENT 5 July 2, 2003 11:29
