LES: fully developed flow at the inlet of a duct
Old   June 12, 2008, 10:28
Default LES: fully developed flow at the inlet of a duct
cfd novice
Hi guys
I wanna impose fully developed flow at the inlet of a duct. I do not have much time so what will be best option to do that. All kind of ideas are welcome. Thanks in advance for your help.
cfd novice
Old   June 12, 2008, 14:32
Default Re: LES: fully developed flow at the inlet of a du
Carlos
Hi!
Take a look at tutorial n°9
Old   June 12, 2008, 14:50
cfd novice
No unfortunately that wont help because that tutorial is for circular pipes. I have a rectangular duct. Any idea how to write an expression for a duct of 2*0.5*0.5? Inlet velocity is 2 m s^-1. Thank you
cfd novice
Old   June 13, 2008, 23:54
Rogerio Fernandes Brito
make a simulation with a long tube! after that, take the profile of velocity at oultlet and use as the inlet for the nest simulation! how about it?
Old   June 14, 2008, 06:40
cfd.novice
Good idea Rogerio but unfortunately I do not have time to run a simulation in very long. If I use periodic boundaries that too would give me fully developed flow. Only problem is that I am being able to use periodic boundaries for compressible flow. Any idea how to sort this issue. Thank you
Old   June 14, 2008, 06:55
if u want, i can make this type of simulation! My MSN is rogeriobrito2007@hotmail.com
Old   June 14, 2008, 12:59
Ahmed
Hi Rogerio
I have added you but you are not online right now. I hope to get in touch with you soon.
Ahmed
Nusselt numbers for fully developed laminar flow Danro Siemens 8 July 19, 2012 07:22
Orifice Plate with a fully developed flow - Problems with convergence jonmec OpenFOAM Running, Solving & CFD 3 July 28, 2011 05:24
translational periodic BC vs Fully Developed Profile at Inlet Prakash.Paudel FLUENT 1 August 20, 2010 11:01
what is the fully developed fluid flow? charles CFX 7 November 13, 2006 09:48
fully developed flow in diffusor Fabian CFX 1 September 19, 2001 18:13
