Solidworks CFX
Old   June 9, 2008, 06:03
Default Solidworks CFX
MAB
Is it possible to import solidworks geometry file into CFX? Thanking in advance.
Old   June 9, 2008, 07:59
Default Re: Solidworks CFX
Mehul
Yes , why not.
If you can solid works in parasolid text (.x_t). Then you can import geometry with "Import Geometry" .. It should work now.
Old   June 9, 2008, 11:42
CycLone
Better still, get the SolidWorks interface for Workbench.
Old   June 10, 2008, 05:03
MAB
hi CycLone, Could you please explain a bit more(SolidWorks interface) . I personnaly dont know Solid works but want to import someone elses geomtry file into CFX. ~Any suggestion??
Old   June 10, 2008, 09:43
Sans
hi, read this http://www.ansys.com/Products/icemcf...solidworks.htm
It doesnt come as a default, need to pay for it. Its pretty useful while performing optimization studies wherein your CAD geometry requires frequent updates. The same interface can be used to import *.SLDPRT files directly into CFXMesh, design Modeller etc.
Old   June 10, 2008, 11:28
CycLone
Hi MAB,
The interface works directly with a live SolidWorks session, so you would need SW installed and licensed to import the file. If you don't have it, ask your friend to export the file to Parasolids.
-CycLone
Old   June 10, 2008, 12:37
MAB
Thank you Sans and CycLone...you are genius.
CycLone!!.... I think there's no ICEM on my CFX.. Do I need ICEM to import a Solidworks file or Parasolid file.???? How to check if i have ICEM or NOT?? I dont have any ADVANCE MESHING option on my project page
Old   June 11, 2008, 11:11
CycLone
Call tech support.
Old   June 12, 2008, 12:38
Rogerio Fernandes Brito
Yes! Choose this type of file to import at Workbench: .SLDPRT
Pros and Cons for CFX, CFdesign, COMSOL Val Main CFD Forum 3 June 10, 2011 02:20
Solidworks + CFX - Mesh fabioacfoz ANSYS Meshing & Geometry 6 August 13, 2009 10:19
PhD using CFX Rui CFX 9 May 28, 2007 05:59
CFX 4.4 installation problem Pandu Sattvika CFX 1 December 1, 2001 04:07
