domain interface on CFX 11
Old   June 21, 2008, 16:15
Default domain interface on CFX 11
Rogerio Fernandes Brito
I am exactly obliged to use this type of interface? That is, I always have to create a domain of the type interface when I have a fluid and a solid or when I have a solid with the other solid?
¿Me obligan exactamente a utilizar este tipo de interfaz? ¿Es decir, tengo que crear siempre un dominio del tipo interfaz cuando tengo un flúido y un sólido o cuando tengo un sólido con el otro sólido?
Old   June 22, 2008, 18:41
Default Re: domain interface on CFX 11
Fluid to solid - yes, need an interface. Solid to solid - if you have defined different materials to the solids then yes you need an interface.
Can CFX do CHT simulations with a solid domain rotating in a stationary fluid domain? acro CFX 15 September 23, 2016 11:16
Expression with time function kestasposkus CFX 28 July 24, 2011 06:47
CFX domain comparison Kiat110616 CFX 4 April 3, 2011 22:43
Proper output of angle of attack in CFX post Kevin CFX 3 October 18, 2006 12:18
Fluid-2 domain interface harry CFX 0 November 6, 2004 06:01
