Momentum Source Value
Old   June 25, 2008, 00:40
Default Momentum Source Value
Siva.K
Hi all, could any body help me defining the momentum source value for my problem. i understand that
Momentum Source X Component = -C*(u-uspec)
how could i come out with the value for "C" my domain is a compressor blade i did a calculation as follows
Momentum source = -c*m(v2-V1) where C - 10e5 m - mass flow rate V2 - exit velocity from the blade V1 - inlet velocity to the blade
will it work if not how should i specify to get the right velocity and pr raise across the blade
[swak4Foam] swak4foam building problem GGerber OpenFOAM Community Contributions 54 April 24, 2015 16:02
Simulation of Axial Fan Flow using A Momentum Source Subdomain Liam CFX 28 July 16, 2013 08:24
pisoFoam compiling error with OF 1.7.1 on MAC OSX Greg Givogue OpenFOAM Programming & Development 3 March 4, 2011 17:18
DxFoam reader update hjasak OpenFOAM Post-Processing 69 April 24, 2008 01:24
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 17:51
