July 1, 2008, 09:21 |
Heat Flux display in CFX post
Hi-
Using ANSYS CFX, I have obtained a transient solution with heat transfer. I want to look at the heat fluxes and can't figure out how. In the drop down menu of variables, i can find the temperature, pressure and velocities, but not the heat flux. I can see Heat Flux in the list of Variables. But don't know how to view the results for that variable. Any help? Thanks in advance |
July 1, 2008, 20:49 |
Re: Heat Flux display in CFX post
Did you try clicking the three dots beside the variables drop down menu?
July 2, 2008, 07:14 |
Do as johnny suggests (click on '...'), then scroll down to 'Wall heat flux' (not 'Heat flux') if it's heat fluxes at surfaces you want, which it usually is.
As for fluxes within the interior of a domain, I've not figured that out quite myself.... but then I rarely want that anyway. Good luck, andy |
July 2, 2008, 08:17 |
yea..I figured that out eventually...Btw, what is the difference between WALL HEAT FLUX and HEAT FLUX?
Sign of Heat Flux at wall | Kyung | FLUENT | 2 | February 26, 2016 16:25 |
Applying Heat Flux out of the surface in CFX | Ijaz | CFX | 3 | February 26, 2009 16:33 |
solar heat flux through roof | Tim | FLUENT | 1 | January 17, 2007 16:01 |
Heat flux post processing in vector form | leo | FLUENT | 6 | June 20, 2001 14:01 |
Heat Transfer Coeff. at Heat Flux Boundary | Rushyen | CFX | 6 | January 18, 2001 05:09 |
