LES turbulence decaying in channel flow
Old   July 3, 2008, 17:08
Default LES turbulence decaying in channel flow
cfdIsMad
Hi
I am running a channel flow using LES. My problem is that turbulence after developing for a bit starts to decay in channel. And after a while I see zero turbulence in my domain. What can I do under such circumstances to sustain the turbulence. Thank you for your answer.
Old   July 3, 2008, 18:25
Default Re: LES turbulence decaying in channel flow
Accurate LES modelling is not easy, I hope you are not a CFD beginner. If you have not heard of the -5/3 line or never drawn a turbulence spectrum then I suggest you do some study of turbulence theory before proceeding.
A major problem in LES modelling is dissipative advection schemes causing energy to lost numerically before it trickles down the subgrid model. To counter this most LES models use central differencing as it does not have the numerical dissipation of the default upwinding schemes.
Old   July 3, 2008, 18:35
cfdIsMad
Hi Glenn
CFX is using central difference scheme, yet it cant sustain the turbulence. I know how to draw energy spectrum and I understand the basic physics of LES. I will be thankful if you can give any hints/suggestions to model plane channel flow so that I can sustain turbulence and get fully developed flow.
I am using periodic boundaries and I have set pressure drop between inlet and outlet. Do I need to set up pressure gradient as well under subdomain???
Thanks in advance
Old   July 3, 2008, 22:17
You are using translational periodic boundaries with a pressure drop? That should be sufficient, the flow rate should then adjust so the pressure drop in the domain equals the pressure rise is the periodicity.
No need to define a subdomain.
Glenn
Old   July 4, 2008, 06:29
cfdIsMad
Hi Glenn
Yes, I am using translatinal periodic boundary with the pressure drop. Thank you for you answer.
Turbulence dampening due to magnetic field in LES and RAS eelcovv OpenFOAM 0 June 8, 2010 11:35
About Turbulence Intensity (Pipe flow assimilated) gRomK13 Main CFD Forum 1 July 10, 2009 03:11
Discussion: Reason of Turbulence!! Wen Long Main CFD Forum 3 May 15, 2009 09:52
LES channel flow Hadi FLUENT 0 September 20, 2007 05:15
fluid flow fundas ram Main CFD Forum 5 June 17, 2000 21:31
