Water Waves in 2D
Old   July 16, 2008, 08:25
Default Water Waves in 2D
MAB
I have generated waves by perscribing velocities (u and v) on the inlet with initial conditions of zero velocities. it seems to work fine in 3D but when i try to run the same simulations on a 2D mesh it fails with an error (fatal overflow or sometimes not enough memory while there is enough memory) Any Suggestion please. Thanks
Old   July 16, 2008, 22:17
Default Re: Water Waves in 2D
Rogerio Fernandes Brito
2D mesh??? at Fluent??
Old   July 17, 2008, 01:52
I assume you have set up your 2D simulation as a mesh one element thick with symmetry planes on either sides.
Sounds like a setup problem. Check things are oscillating in the correct directions.
Old   July 17, 2008, 05:38
MAB
hi . yes it is extruded 2D mesh with one element think and symmetry planes at fron and back. the simulation works if i make initial values(of velocity) same as the boundary values at inlet. but i want to run it for a zero initial velocity. and it works in 3D
Old   July 17, 2008, 05:52
MAB
it is CFX. 2D extruded mesh. also i have place a line control(followed by a point controle) to refine the mesh at free surface. i think it is the mesh but how can i controle it
Old   July 17, 2008, 12:11
MAB
hi Glenn.H. the 2D simulation works in the absense of line spacing( which i have used to refine the mesh at free surface) ... any further suggestion please...?
Old   July 17, 2008, 21:48
Are you sure you are using symmetry planes for the top and bottom faces? Is the thickness of your extrusion approximately equal to the smallest element length?
Old   July 18, 2008, 04:29
MAB
front and back is symmetry planes. while top is open boundary and bottom is a wall . left is inlet and right is outlet/opening...
Water subcooled boiling Attesz CFX 7 January 5, 2013 03:32
Modelling Propagating 2d water waves ubaka Main CFD Forum 2 October 18, 2012 20:56
Papers request-Generation of water waves by source Mehdi BEN HAJ Main CFD Forum 0 June 11, 2007 12:55
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 09:11
uptodate water distribution network fredius,magige,tanzanian,(e.a) Main CFD Forum 0 January 27, 2002 07:10
