ICEM-CFD
Old   July 19, 2008, 16:25
Default ICEM-CFD
Rick
Is there a way to run ICEM-CFD as a batch process (without GUI). I have recorded the script file which I want to run from a command line interface.
I know for ansys you do ...."add ansys" then run the batch file. How do you do it in ICEM-CFD?
Thanks Rick
Old   July 20, 2008, 12:29
Default Re: ICEM-CFD
Charles
icemcfd -cfd -batch -script makemesh.rpl
Where makemesh.rpl is obviously your own journal file.
Old   July 21, 2008, 16:58
Rick
Thanks Charles.
I used the command but got an error message
The ICEM_ACN environment is not set. ICEM_ACN: Unidefined Variable
How can I fix this?
Old   July 30, 2008, 07:50
Default ICEM_ACN, was Re: ICEM-CFD
Alan Magnuson
ICEM_ACN is an environment variable that points to the directory where ICEM CFD is installed. If you set it properly and do a "ls $ICEM_ACN" or "dir %ICEM_ACN" you should see a set of directories, "bin", "lib", etc.
Al Magnuson
Old   July 30, 2008, 09:17
Default Re: ICEM_ACN, was Re: ICEM-CFD
Rick
Thanks Al
[ICEM] Icem CFD on Linux mechanicaldesign ANSYS Meshing & Geometry 7 March 11, 2021 19:44
Need help icem cfd kakhtar ANSYS Meshing & Geometry 25 January 31, 2017 01:09
Transport mesh from ICEM CFD, to Fluent, to Sysnoise Wieland FLUENT 2 April 15, 2012 06:28
Importing Solidworks part into ICEM CFD MetalSupremacist FLUENT 0 October 8, 2010 17:46
Which is better to develop in-house CFD code or to buy a available CFD package. Tareq Al-shaalan Main CFD Forum 10 June 12, 1999 23:27
