Extruded Periodic Pair warning help
Old   July 31, 2008, 09:36
Default Extruded Periodic Pair warning help
siw
I'm meshing an aerofoil for a 2-D simulation. I've set up an Extruded Perodic Pair in the spanwise direction to that I get 1 element thickness. However, when applying the various spacings, controls etc and viewing the surface mesh I always get the following warning:
One of more face or edge spacings may not have the desired effect because they have been set to objects that are not associated with the extruded periodic pair. You might want to try using point, line or triangle controls to achieve the required mesh spacing in the periodic regions.
What does this really mean and how do I fix it?
I've got point controls on the leading and trailing edges, on both sides of the periodic walls to increase the meash density at these curved places.
Thanks
latest OpenFOAM-1.6.x from git failed to compile phsieh2005 OpenFOAM Bugs 25 February 9, 2010 04:37
Version 15 on Mac OS X gschaider OpenFOAM Installation 113 December 2, 2009 10:23
Compilation errors in ThirdPartymallochoard feng_w OpenFOAM Installation 1 January 25, 2009 06:59
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 14:00
Warning 097- AB Siemens 6 November 15, 2004 04:41
