August 8, 2008, 10:19 |
Restart from .bak file
How can I restart a crashed simulation using the last back-up file (.bak)? My simulation is a distributed parallel run between 13 processors running Linux, and I start it from the command line using a shell script. Thanks! |
August 9, 2008, 01:10 |
Re: Restart from .bak file
Hi, On windows, if its a full backup file just rename your .bak file to .res and you can restart.
August 9, 2008, 10:30 |
Hi, thanks for your response. You say "if its a full backup file." Does this mean including all the variables or does it mean just the primitive variables (P,u,v,w) and the mesh? Thanks!
August 11, 2008, 06:59 |
on linux use the mv command to change "bak" to "res".
Regards |
August 11, 2008, 18:00 |
No need renaming the file. You can just start the solver using the backup:
cfx5solve -def File.def -ini iteration.bak Off course it will only "restart" the variables available on the backup file. So, if you only saved P, U, V, W, these will be the only variables "restarted". |
2.0.x on Mac OSX | niklas | OpenFOAM Installation | 74 | March 28, 2012 16:46 |
[Gmsh] Compiling gmshFoam with OpenFOAM-1.5 | BlGene | OpenFOAM Meshing & Mesh Conversion | 10 | August 6, 2009 04:26 |
DxFoam reader update | hjasak | OpenFOAM Post-Processing | 69 | April 24, 2008 01:24 |
Regarding FoamX running Kindly help out | hariya03 | OpenFOAM Pre-Processing | 0 | April 18, 2008 04:26 |
Problem with rhoSimpleFoam | matteo_gautero | OpenFOAM Running, Solving & CFD | 0 | February 28, 2008 06:51 |
