Center of Pressure
Like Tree1Likes
  • 1 Post By Yakn
Old   July 27, 2008, 23:31
Default Center of Pressure
Yakn
I know this has been posted previously; however, I did not find the posted information helpful and I'm hoping there are people out there who might be able to help me with the issue.
I am trying to find the center of pressure for a vehicle in CFX. I tried both CEL Expressions and the force/torque equations method suggested in previous posts. The first gives me numbers that seem unreasonable. The latter doesn't work either...multiple solutions essentially.
Any other suggestions or any ideas why the CEL Expressions aren't working? I can post up what I used if there are any questions regarding that.
Thanks, Ykan.
Old   July 28, 2008, 01:57
Default Re: Center of Pressure
I have done it before, it works fine. Please post your CEL and we will have a look.
Old   July 28, 2008, 09:20
Yakn
Thanks for the reply. The following are the equations being used. This is for head-on flow (ie. a velocity component only in the x direction).
CPX=((areaInt_x(X*Pressure)@car+areaInt(X*Wall Shear X)@car)) /((areaInt_x(Pressure)@car+areaInt(Wall Shear X)@car))
CPY=((areaInt_y(Y*Pressure)@car+areaInt(Y*Wall Shear Y)@car)) /((areaInt_y(Pressure)@car+areaInt(Wall Shear Y)@car))
CPZ=((areaInt_z(Z*Pressure)@car+areaInt(Z*Wall Shear Z)@car)) /((areaInt_z(Pressure)@car+areaInt(Wall Shear Z)@car))
Sherif.tr likes this.
Old   July 30, 2008, 01:42
Yakn
Any comments anyone?
Thanks....
Old   July 30, 2008, 22:10
hi,
Use the force_x and torque_x functions. Something like:
CPX = torque_x()@car / force_x()@car
Old   August 1, 2008, 14:43
Yakn
Thanks for the response. I tried that but I'm getting really small values. They don't make sense.....
Also, in terms of torques and forces, shouldn't the forces in the z direction and y direction contribute to the torque about the x-axis?
Thanks, Yakn.
Old   August 3, 2008, 18:49
Sorry, yes you are right, you will need to fix the vector directions up.
Old   August 4, 2008, 02:15
Yakn
Ok. However, if I try to set up a matrix of the force and torque relations relative to the center of pressure, I get a skew-symmetric matrix which cannot be inverted to solve for the center of pressure.
Is there a way to do this without using the torques and forces method?
Thanks, Yakn.
Old   August 9, 2009, 18:57
Michael Donovan Almighty
mr.almighty is on a distinguished road
Originally Posted by Yakn
;89261
Thanks, Yakn.
so the only way is to calculate by your self. There is not any feature in CFX in order to obtain the center of pressures. In my case I hace calculated the flow around a rocket and the next step is locating the Cp, but I don't know how to obtain it by CFX... Is very sad use the tipical ms-dos software to obtain the Cp with a basic sketch of my rocket... Can anyone help me?
thank you very much!!
mr.almighty is offline   Reply With Quote
Old   August 9, 2009, 19:22
My original post was incorrect. Yes, you have to calculate it but it is not that hard. From the definition of Torque = r x F, where r is the displacement vector to the point the force acts on and F is the force vector. You can get the torque vector using the torque_x, torque_y and torque_z commands and similarly the forces using force_x, force_y and force_z. It is just then a matter of expanding out the cross product and solving for the displacement vector.
Old   August 11, 2009, 12:39
I have calculated the center of pressures obtaining previously the force and the torque pressure net over the surface of my rocket. After that I have made a change of center of reduction of the moment: Mo=Mp+OPxF, where Mp is 0 beacuse P is the center of pressures and I only have had to solve a linear system of equations in order to obtain the coordinates of the center of pressures (OP). In my case "O" is the coordinates origin son P is directly the coordinates of the center of pressures.
Pressure Rise Error emueller CFX 0 May 5, 2009 11:08
center of pressure location for car praveenreddy FLUENT 2 December 3, 2007 11:33
variation of center of pressure with angle of atta Virag Mishra CFX 0 August 27, 2007 10:27
Center of Pressure Astrid CFX 0 December 21, 2006 04:07
center of pressure with fluent giorgio FLUENT 0 June 29, 2004 12:36
