2D Drag Coefficient
Old   August 1, 2008, 11:06
Default 2D Drag Coefficient
Dre
So I'm having problem trying to figure out what to do with the area term in the drag coefficient formula.
Since it's in 2D, you usually replace the area term with just the diameter (in this case for a cylinder).
But now with CFX, since you can't really do a 2D simulation, do you just take the diameter, or do you need to take into consideration the thickness of that one element?
Old   August 3, 2008, 18:39
Default Re: 2D Drag Coefficient
2d drag coefficient of what?
These relations need a representative length. For a sphere or cylinder the diameter is th obvious length, for a square the length of the side. How you model it is totally separate.
Old   August 4, 2008, 16:11
Dre
I am modelling a cross section of a cylinder.
My problem is do I take the frontal area, or do I take the diameter.
Since it's 2D, I should take the diameter, but since it's in CFX, do I take the diameter multiplied by the thickness of the element?
Old   August 4, 2008, 21:55
I think you will find the diameter equals the frontal area. It did last time I looked at a cylinder anyway.
Most of these coefficients use unit length, in SI units that is 1 metre. If your element thickness is different to a metre then you need to scale the forces to account for that.
Drag Coefficient Convergence Problem John FLUENT 18 June 24, 2023 09:22
drag coefficient in ansys fluent 12.0 krishna FLUENT 19 April 12, 2018 00:49
Incorrect Drag and Drag Coefficient for flow over a cylinder ozzythewise Main CFD Forum 8 June 13, 2012 06:24
Drag coefficient for parcels in dieselFoam sebastian_vogl OpenFOAM Running, Solving & CFD 5 December 31, 2008 12:19
Automotive test case vinz OpenFOAM Running, Solving & CFD 98 October 27, 2008 08:43
