Plotting Vorticity in CFX 11
Old   July 24, 2008, 06:38
Default Plotting Vorticity in CFX 11
Venkatesh
I am using CFX 11. My problem is I want to plot vorticity in the results. I have included the vorticity information in the CCL file and added it to the .def file. But when use this def file and generate the results and try to plot vorticity in cfx post 11, I could not find the variable information for VORTICITY. Could u pls help me with this.
If it will not work, please also suggest me an alternative method to work this out.
Thanks Venky.,
Old   July 25, 2008, 17:24
Default Re: Plotting Vorticity in CFX 11
Rogerio Fernandes Brito
How did you define the vorticity?
Old   July 26, 2008, 04:11
Sans
Hi, This query has been answered here before, you may perform a search for more info. Simplest method is to goto to your VARIABLES files in the Etc folder and set the 'Output to Postprocessor' to 'Yes'for the Vorticity variable.
Old   July 26, 2008, 07:49
SO CFX´d already been had this variable!
Old   August 6, 2008, 06:26
Venkatesh
We have common server from where we use CFX. So the folder ETC I could not access. So, what I am trying to do is open CFX-PRE and then export my def file as a CCL file and add the following lines of code,
VARIABLE: vorticity
Output to Postprocessor = Yes END
and then importing it back into the PRE. But when I run the analysis, I could not see any variable called vorticity in the results file. Can someone throw light on this? I know I can write an expression for vorticity but I want to make use of this default setting provided by ICEM.
Venky/.
Activate vorticity rikio CFX 3 October 27, 2017 10:58
Different flow pattern between OpenFOAM and CFX AirS OpenFOAM 0 January 12, 2010 07:08
heat generation in CFX Ema CFX 4 August 7, 2009 05:39
Electronics Enclosure Analysis with CFX Simulation Engineer CFX 1 April 22, 2009 11:08
CFX 4.4 installation problem Pandu Sattvika CFX 1 December 1, 2001 04:07
