August 9, 2008, 06:22 |
Turbomachinery
Which CFD software is best for simulating the Compressor flows. 1. Fluent 2. CFX 3. Numeca
and please also give the advantages and disadvantages of all three softwares. Also if any one knows about any other better software for compressor flow do write here the name of that software. Best Regards SA |
August 9, 2008, 09:49 |
Re: Turbomachinery
About Fluent and CFX, you could make contact with the hawker at http://www.esss.com.br/index.php?pg=empresa_contato.
To build your geometry, u can use BladeGen and TurboGrid, tools within the ANSYS Products 11. |
August 11, 2008, 12:55 |
Re: Turbomachinery
I only do a little bit of work in this field, but my understanding is that CFX is the gold standard in turbomachinery applications due to its handling of rotating frames and the specific applications such as turbogrid. We have a turbomachinery group where I work, and they did some software research and bought CFX. People from other companies (Fluent - although now also owned by ANSYS) and CFD++ both have agreed with this assessment that CFX is the best for this application in the past. From my experience - I have found it quite easy to use for this sort of work.
-Alex |
August 12, 2008, 12:45 |
Re: Turbomachinery
CFX coupled with bladegen and turbogrid is the best option.
August 19, 2008, 01:26 |
Re: Turbomachinery
hi 1)In case you will simulate turbomachinery components(steam turbines,gas turbine,compressors,fans) very best usfull software:CFX software 2)In case you will simulate other componets(boilar heat exchangers,all heat transwar components components) ver very usfull:Fluent
Display Modes | |
Are OSIG TurboMachinery libraries able to work under OpenFOAM-1.6-ext? | alkochevsky | OpenFOAM Installation | 26 | June 8, 2014 16:22 |
Turbomachinery at OpenFOAM Workshop Milan 2008 | hani | OpenFOAM | 0 | March 21, 2008 03:33 |
best CFD software for turbomachinery | sam | Main CFD Forum | 10 | April 13, 2007 16:42 |
GAMBIT and Turbomachinery | tom | Main CFD Forum | 6 | October 21, 1999 10:50 |
ERCOFTAC Seminar and Workshop on TURBOMACHINERY FLOW PREDICTIONS VII | Stephane AUBERT | Main CFD Forum | 1 | October 9, 1998 17:37 |
