fluid pressure in cavity
Old   November 2, 2008, 18:51
Default fluid pressure in cavity
Nishan
I am trying to obtain the pressure in a fluid that is surrounded by a flexible hose and two aluminium plates on the top and bottom. (Basically a cylindrical tube, which has 2 plates bonded to the ends of the tube to create a cavity in the center, where the cavity is filled with incompressible fluid). I fix one plate and apply a 10N force to the other plate.
Hypothesis: I should get a pressure build up in the fluid which is equivalent to F/A.
I constructed this sort of consfiguration, and measured the pressure with a pressure sensor. Results were as expected. But I cannot model this in ansys wb/cfx. I am doing a coupled fsi.
Maybe I am using an incorrect material to model the water. I use 'constant property liquid' and 'water data'. Is this correct? if not what material should i use to see an increase in pressure with applied load.
Wind turbine simulation Saturn CFX 58 July 3, 2020 01:13
Fluid flow caused by initial pressure difference perry.fox FLUENT 1 December 24, 2010 08:42
Modelling a Herschel Bulkley fluid with yield stress proportional to fluid pressure carrotlaw OpenFOAM 0 August 18, 2010 06:57
pressure gradient term in low speed flow Atit Koonsrisuk Main CFD Forum 2 January 10, 2002 10:52
what the result is negatif pressure at inlet chong chee nan FLUENT 0 December 29, 2001 05:13
