expression with variable domains
Old   October 15, 2008, 15:34
Default expression with variable domains
jpshulf
I want to create an expression used to define a boundary condition.
The expression needs to be able to calculate the specified boundary condition at different time(s).
For example, the inlet velocity for one of my boundary conditions is defined as:
(3*t+5), for t<2
(11), for t>2
(-12t+14), for t>5
I tried messing aronud with the step function, but I don't believe this is the right approach. Any help would be greatly appreciated.
Old   October 15, 2008, 20:33
Default Re: expression with variable domains
Either use the step function or an interpolation function. There are no other options.
In CFX V12 you will be able to use an if function.
Old   October 16, 2008, 01:50
Georg
(3*t+5)*step(2-t)+11*step(t-2)*step(5-t)+(14-12*t)*step(t-5) Becouse Step is dimensionless function you should use t/1[s] insted of t (if t=time, of course). All parts of expression must have Velosity units. So, finally expression is ((3*t+5[s])*step(2-t/1[s])+11[s]*step(t/1[s]-2)*step(5-t/1[s])+(14[s]-12*t)*step(t/1[s]-5))*1[m/s^2] Not so camfortable as "if" "else" but it works. I hope it help you.
Old   November 14, 2008, 17:46
jpshulf
Thank you very very much!!!
emag beta feature: charge density charlotte CFX 4 March 22, 2011 09:14
How to install CGNS under windows xp? lzgwhy Main CFD Forum 1 January 11, 2011 18:44
CGNS lib and Fortran compiler manaliac Main CFD Forum 2 November 29, 2010 06:25
error in COMSOL:'ERROR:6164 Duplicate Variable' bhushas COMSOL 1 May 30, 2008 04:35
Replace periodic by inlet-outlet pair lego CFX 3 November 5, 2002 20:09
