Notice in CFX
Old   November 18, 2008, 07:24
Default Notice in CFX
Marek
Hi
I am trying to simulate two phase flow in combustion chamber using CFX 10. After few more than 10 iterations I get message: __________________________________________________ __________
Newtons method failed to converge in 100 iterations. This occurred while computing the following variable:
Variable Name : C3H8.Temperature Location Name : fluid Mesh location : VERTICES Mesh entity : Last 3 Changes : 1.50603E+03 1.50603E+03 1.50603E+03 Tolerance : 1.0000E-02
The Newton iteration was either slowly converging or has stalled. The solver will continue with the variable set as it was on the final iteration. If this situation continues you might try increasing the number of iterations allowed for Newtons method. This can be changed by setting one of the parameters:
Temperature : "Constitutive Relation Iteration Limit" Pressure : "Newton Pressure Iteration Limit"
for your mixture using the definition file editor.
Soon after first message solver stops. I don't understand how to improve definition file taking into account this notice.
Thanks in advance Marek
Old   November 18, 2008, 07:56
Default Re: Notice in CFX
Ahmad Al-Zoubi
Dear Marek,
Try to run your case 5 iterations and then check your solution, especially the velocity profile. This problem sometimes occurs because of very high velocities.
Regards
Ahmad
CFX 12.1 Notice Roland R CFX 1 March 10, 2011 13:17
Notice of wall condition in cfx td2e09 CFX 0 August 5, 2010 10:17
cfx one of notice message canter CFX 1 November 21, 2008 05:45
notice in CFX solver sravani CFX 3 September 27, 2007 13:01
PhD using CFX Rui CFX 9 May 28, 2007 05:59
