Surface : Patran to csv
Old   December 11, 2008, 07:50
Default Surface : Patran to csv
H. SJ
I have created some 2D surfaces in Icem CFD.
I have exported them in the Patran Neutral File.
I need to edit them and then save them in the csv format.
The goal is to use them as surface user in CFX-Post.
However, I don't know what to add, remove, ..., when editing the Patran files and converting them in CSV files.
Anyone knows ???
Regards,
H.
[ICEM] Problems with coedge curves and surfaces tommymoose ANSYS Meshing & Geometry 6 December 1, 2020 11:12
[Gmsh] Error : Self intersecting surface mesh, computing intersections & Error : Impossible velan OpenFOAM Meshing & Mesh Conversion 3 October 22, 2015 11:05
[Gmsh] Problem with Gmsh nishant_hull OpenFOAM Meshing & Mesh Conversion 23 August 5, 2015 02:09
[Gmsh] boundaries with gmshToFoam‏ ouafa OpenFOAM Meshing & Mesh Conversion 7 May 21, 2010 12:43
CFX4.3 -build analysis form Chie Min CFX 5 July 12, 2001 23:19
