Tutorial 21 error from CFX-solver!
Old   December 1, 2008, 20:50
Default Tutorial 21 error from CFX-solver!
Faraaz
Hi everybody, I got the following error message from CFX-solver when running tutorial 21,which is a moving mesh problem. I got this dialog box :
/COM,ANSYS RELEASE 11.0 UP20070125 01:32:00 12/02/2008
*** FATAL *** CP = 1.016 TIME= 01:32:01 The database (-db) space requested is not currently available. Reenter ANSYS command line with less database space requested.
************************************************** ********************** The above error is non-recoverable by ANSYS ANSYS run terminated by the indicated error Current data base saved if possible. ************************************************** **********************
When i clicked OK, then there was this error message on the right of the CFX-solver (Out file):
----------------------------------------------------------- An error has occurred in cfx5solve: ANSYS Solver terminated unexpectedly with return code 3840 ----------------------------------------------------------- This run of ANSYS CFX Solver has finished
Can someone please help me through this?
Old   December 2, 2008, 13:54
Default Re: Tutorial 21 error from CFX-solver! Solved..
Faraaz
Hey guys, thanks anyway. The problem was fixed just by installing the required programs. I installed MS Platform SDK 2003, Ms Visual C++ Express edition 2005 and finally Fortran 9.0.
Working directory via command line Luiz CFX 4 March 6, 2011 20:02
CFX SOLVER error !!! mehrdadeng CFX 3 November 23, 2009 16:42
mach number and CFX 11.0 solver turbinesv CFX 5 January 5, 2009 05:43
CFX Solver to run 10 files sequentially Raj CFX 8 October 29, 2008 22:20
problem in CFX solver about isolated volumes Yuan CFX 2 August 16, 2004 22:54
