Orthogonality Angle
Old   December 1, 2008, 19:12
Default Orthogonality Angle
Tristan
The CFX11 Solver Guide lists the orthogonality angle as one of the measures of mesh quality. It's defined as the "area weighted average of angles between n and s vectors for all integration point surfaces of a control volume". The accompanying diagram then shows an example of orthogonality where n and s align, and non-orthogonality where n and s do not align. If non-orthogonality is "bad" then why is the acceptable range for the orthogonality angle >20 degrees? Don't you want n and s to align thereby producing a small orthogonality angle?
Tristan
Old   December 2, 2008, 10:27
Default Re: Orthogonality Angle
CycLone
90 degrees = orthogonal
This is the angle between the line connecting two nodes and the face (as opposed to the face normal). This definition was used because it was more consistent with the more common measure of face angle.
-CycLone
Old   December 2, 2008, 12:11
Tristan
CycLone,
Face? Which face? Are you talking about an integration point surface. I apologize for the the confusion but it seems that the CFX-solver checks 3 measures of mesh quality (orthogonality angle, aspect ratio, mesh expansion factor) that you can't look at directly in CFX-post because it only provides "related" measures (min/max face angle, edge length ratio, element volume ratio). Of course, the smoothing options in ICEM are for different "related" measures. If I ever make a grid for a "real" geometry that actually passes the CFX-solver checks, it will be a miracle!
Thanks,
Tristan
InterFoam contact angle JoaoMiranda OpenFOAM Running, Solving & CFD 7 October 20, 2016 06:27
[Netgen] Import netgen mesh to OpenFOAM hsieh OpenFOAM Meshing & Mesh Conversion 32 September 13, 2011 05:50
Normal vector, slope and aspect angle g_niro Main CFD Forum 0 February 2, 2011 17:24
Minimum Orthogonality Angle Farid CFX 1 June 20, 2008 12:51
angle of attack kiran FLUENT 0 September 10, 2004 08:18
