December 1, 2008, 20:50 |
Tutorial 21 error from CFX-solver!
Hi everybody, I got the following error message from CFX-solver when running tutorial 21,which is a moving mesh problem. I got this dialog box :
/COM,ANSYS RELEASE 11.0 UP20070125 01:32:00 12/02/2008 *** FATAL *** CP = 1.016 TIME= 01:32:01 The database (-db) space requested is not currently available. Reenter ANSYS command line with less database space requested. ************************************************** ********************** The above error is non-recoverable by ANSYS ANSYS run terminated by the indicated error Current data base saved if possible. ************************************************** ********************** When i clicked OK, then there was this error message on the right of the CFX-solver (Out file): ----------------------------------------------------------- An error has occurred in cfx5solve: ANSYS Solver terminated unexpectedly with return code 3840 ----------------------------------------------------------- This run of ANSYS CFX Solver has finished Can someone please help me through this? |
December 2, 2008, 13:54 |
Re: Tutorial 21 error from CFX-solver! Solved..
Hey guys, thanks anyway. The problem was fixed just by installing the required programs. I installed MS Platform SDK 2003, Ms Visual C++ Express edition 2005 and finally Fortran 9.0.
Working directory via command line | Luiz | CFX | 4 | March 6, 2011 20:02 |
CFX SOLVER error !!! | mehrdadeng | CFX | 3 | November 23, 2009 16:42 |
mach number and CFX 11.0 solver | turbinesv | CFX | 5 | January 5, 2009 05:43 |
CFX Solver to run 10 files sequentially | Raj | CFX | 8 | October 29, 2008 22:20 |
problem in CFX solver about isolated volumes | Yuan | CFX | 2 | August 16, 2004 22:54 |
