December 4, 2008, 17:12 |
Lift & Drag forces from Transient Analysis
If I run a transient analysis, how do I get the force to use for calculating the drag and lift coefficient, since the force change with time ?
December 4, 2008, 17:40 |
Re: Lift & Drag forces from Transient Analysis
Either post-process it in CFX-Post for each transient result file you saved or set up a monitor point with a function like force_x()@surfacename and when you run the simulation you can access the forces in Solver Manager. Glenn Horrocks |
[OpenFOAM] Calculating Lift and Drag in Paraview (paraFoam) | scott | ParaView | 26 | August 22, 2019 06:26 |
Measure lift and drag forces in 3D | henna07 | ANSYS | 1 | October 17, 2011 16:18 |
coefficient of lift and drag forces | nkiru | FLUENT | 9 | August 14, 2008 01:00 |
Drag and Lift forces extremely low | João Lourenço | FLUENT | 4 | January 28, 2008 13:25 |
High lift analysis using overset | kei-tee | Main CFD Forum | 0 | April 10, 2003 09:53 |
