Turbulent Reynolds
Old   December 9, 2008, 14:41
Default Turbulent Reynolds
Michael Groll
I have seen several values for Reynolds number while doing some research on this topic for what is considered to be turbulent flow. I have seen, at minimum, >2,000 Re. Then I have seen >3,000, >4,000, and I have seen a couple sources state that >10,000 Re is considered turbulent. How is one to determine an accurate measurement for what is considerd turbulent flow?
Old   December 9, 2008, 17:28
Default Re: Turbulent Reynolds
It depends on many factors, that is why there is not a single "accurate" number. I assume you are talking about pipe flow. The Re for transition to turbulence depends on many factors, such as upstream disruptions, surface roughness, vibrations and many others. In a lab where you can make an almost ideal laminar flow you can extend the transition point to quite high Re numbers. In the real world with rough pipes, vibrations and upstream effects it pushes it back to around Re=2000.
On top of that there is also hysteresis effects - the Re number is going from turbulent to laminar flow tends to be lower than going from laminar to turbulent.
Low Reynolds number k-E Turbulent Model Sohail FLUENT 19 July 16, 2020 14:08
Calculate turbulent reynolds number in CFX Jervds CFX 2 May 11, 2009 09:18
How to model Low Reynolds Turbulent in SST K-omega asghari FLUENT 0 August 18, 2007 03:31
Reynolds and Turbulent flow Frederic Dubinski CFX 5 October 21, 2004 04:12
Reynolds and Turbulent Flow Frederic Dubinski Main CFD Forum 2 October 20, 2004 13:57
