how to simulate exhaust of high pressure tank
Old   January 7, 2009, 01:28
Default how to simulate exhaust of high pressure tank
song
Hello, everyone
There are two tanks connected with pipe, one tank has a high pressure of 10 atm and the other one 1atm, by controlling the valve at the middle of the pipe, the high pressured air will be exhausted to the low pressure tank...
first, i just want to simulate the high pressure tank in 2D, one outlet/open outlet set, and the reference pressure is set to be 1atm, the relative pressure in initialization is 9atm, that's ok, i thought.
but the factor is, cfx can't calculate it, i don't know why.
is there anybody interested in this project? could you give me some hints?
thanks in advance.
Old   January 7, 2009, 17:32
Default Re: how to simulate exhaust of high pressure tank
Can you describe how you have set it up? What fluid are you using? What physics?
Old   January 9, 2009, 18:17
Tristan
We had some problems getting a run started for high pressure air flow through a manifold. One way to get the run started was to prescribe an initial pressure field with a linear pressure drop between the inlet and the outlet. If we used a 1 atm reference pressure (as you did) and then a constant initial pressure field, the mach number would blow up in the first few steps.
Tristan
Old   January 11, 2009, 16:54
There are many ways to get tricky transonic simulations to converge, Tristan has mentioned one. Others include starting at a low pressure and ramping the pressure up, starting with upwinding and switching to a higher order scheme later, starting with local timestepping and switching to physical timestepping later, starting on a coarse grid and interpolating to a fine grid for the final run, sometimes expert parameters such as increasing the number of continuity loops helps....
interFoam / bubbleFoam to simulate an aerated tank Meratb OpenFOAM Running, Solving & CFD 3 November 6, 2020 11:45
Calculation of the Governing Equations Mihail CFX 7 September 7, 2014 06:27
Pressure BC for combustion chamber Giuki FLUENT 1 July 19, 2011 11:35
Multicomponent fluid Andrea CFX 2 October 11, 2004 05:12
Hydrostatic pressure in 2-phase flow modeling (long) DS & HB Main CFD Forum 0 January 8, 2000 15:00
