ANSYS CFX Tutorial 7
Old   January 6, 2009, 18:32
Default ANSYS CFX Tutorial 7
Sam
I am working through the tutorials ad have come to tute 7 whihc is the free surface flow over a 2d bump. This tutorial is very applicable to what i would liek to do my thesis on.
When I try to solve the problem I get an error message which reads, "The density-difference buoyancy model is being used, but the buoyancy reference density has not been specified"
I have tried loading the session file supplied but it also comes up with the error when I try to solve it
Has anyone had a similar problem or any advice on how to resolve the problem?
Regards,
Sam
Old   January 7, 2009, 06:29
Default Re: ANSYS CFX Tutorial 7
Rogerio Fernandes Brito
I did some meshes of this case. IF YOU WANT TO use these grids...
http://www.4shared.com/file/65772301..._Mr_Brito.html
http://www.4shared.com/file/65770211..._Mr_Brito.html
Old   January 7, 2009, 16:03
Sam
Thayou I will have a play,
I am very much learning CFD and know quite little about the topic at this stage, I have read a few books Do you know of any other ways to better understand using CFD to generate free surface flows?
I feel the problem may be in the setting up of my problem rather than the meshing but I will try again.
Thanks again,
Sam
Old   January 7, 2009, 17:34
I agree the problem likely to be the setup, not the mesh. The error message refers to the buoyancy reference density - have you set it as it requests?
What version of CFX are you using?
Old   January 7, 2009, 18:03
Sam
I am currently using v11
I am about to have been reading CFX help
"For a flow containing a continuous phase and a dilute dispersed phase, you should set the buoyancy reference density to that of the continuous phase"
My understanding is that the reference density should be that of the water. Do you believe this is correct?
Regards,
Sam
Old   January 8, 2009, 16:23
Yes, you are correct.
Old   January 15, 2009, 07:10
Peter
Did you select both "Air at 25C" and "Water" in the fluid list when defining the domain?
Old   January 24, 2009, 19:48
Leandro Resende
Hi Sam,
Besides what Peter said, you should also set density reference (under gravity force vectors) as the one of the lighter fluid.
In The density difference model only the heavier fluid suffers the gravity force.
See at Help how this model works.
hope was helpful
Setting Pressure Boundary Conditions in ANSYS CFX Pre saisanthoshm88 CFX 21 February 22, 2017 16:50
Calculation of the Governing Equations Mihail CFX 7 September 7, 2014 06:27
URANS in ANSYS CFX brissyben CFX 3 October 6, 2009 17:35
I cannot open Ansys CFX in Workbench Pham Son Minh CFX 2 January 13, 2008 03:33
CFX bought by Ansys - good or bad?! Pete CFX 38 February 21, 2003 07:34
