Multiple domain interfaces on a single surface |
January 25, 2009, 23:17 |
I'm having difficulty applying proper interfaces in a 3D simulation I'm trying to run. I have a two solids, overlapping partially, in an airflow, as seen below. Because of this, the top surface of solid 2 requires a solid-solid interface with Solid 1, and a solid-fluid interface with the surrounding air. |.....Solid.1...|.....Fluid.....| -------------------------- |............Solid.2..............| When I apply both domain interfaces, I get errors saying: "There are 2d regions in boundary 'Domain Interface Side 1' in domain 'solids' that have already been used." and "There are 2d regions in domain interface 'Domain Interface 1' that have already been used" It seems to me that I should be able to partition or split the top face of Solid 2 along the line of contact, but I am unable to find any option to do so in Design Modeller, Meshing, CFX-Mesh, or CFX-Pre. Any help would be greatly appreciated. |
January 26, 2009, 16:45 |
Re: Multiple domain interfaces on a single surface
You can split the face in DM using a Body Operation with the "Imprint Face" option. Unfreeze Solid 2 and freeze all other bodies, then pick Solid 1 and Fluid for the operation, which will then imprint their faces on Solid 2.
-CycLone |
January 26, 2009, 17:03 |
Thank you so much, this is exactly what I was looking for.
-mike |
[ICEM] Problems with coedge curves and surfaces | tommymoose | ANSYS Meshing & Geometry | 6 | December 1, 2020 11:12 |
How to: Domain Interfaces | Neusier | CFX | 8 | March 22, 2011 06:34 |
[Gmsh] boundaries with gmshToFoam | ouafa | OpenFOAM Meshing & Mesh Conversion | 7 | May 21, 2010 12:43 |
CFX 5.5 | Roued | CFX | 1 | October 2, 2001 16:49 |
CFX4.3 -build analysis form | Chie Min | CFX | 5 | July 12, 2001 23:19 |
