September 22, 2009, 07:12 |
initialisation in CFX
Rep Power: 17 |
I am just wondering if I don't set up any initialisation, what initial conditions will be used in CFX simulation. many thanks
littlelz |
September 22, 2009, 09:35 |
Bharath kumar
Rep Power: 17 |
If you don't initialize a problem it takes some more time to get converge.with out initialization you can run a problem
September 22, 2009, 18:04 |
Rep Power: 17 |
thanks. that's exactly what I experienced. I need more time to get converged result. I can run the problem without initialisation. however, I guess CFX must have some estimated initialisation in order to start the running although we don't know exactly what they are.
I am running one problem with M=0.25. If I set nothing for initialisation, it will fail because of overflow. however, if I set freestream conditions as initial data, it will converged very quickly. for another case with M=0.8, without initialisation, it can be converged, but need longer time, with some initial setting, it can be converged quickly. could anyboday give me some explaination on it? many thanks littlelz |
September 22, 2009, 19:45 |
George
Rep Power: 18 |
for any numerical method you need to provide a starting point for the calculations. obviously the closer you are to the solution the faster the process. CFD is no different and choosing realistic initial conditions for your problem will yield to faster convergence. I think the solver will use default initial values for variables if an initialization setup is missing; although I have to say I might be wrong as I dint test the above and I don't particularly try to make my life difficult on purpose.
Top 4 tips 1. Knowledge is everything and Ignorance is dangerous. 2. Understand your limitations and try to eliminate them. 3. Get yerself a bike and hoon the chuffer. You will soon learn why dogs like to hang their heads out the car window. 4. Please before asking any questions on how to run simulations in CFX, go though all the tutorials |
September 23, 2009, 07:33 |
Rep Power: 143 |
If you don't specify anything CFX uses zero for all variables everywhere. For simple stuff this is OK, but tricky simulations need a better guess than this to get started.
September 24, 2009, 06:09 |
Rep Power: 17 |
Pros and Cons for CFX, CFdesign, COMSOL | Val | Main CFD Forum | 3 | June 10, 2011 02:20 |
Importing solutions in CFX. | Alphonso | CFX | 1 | August 1, 2008 14:01 |
Fluent Vs CFX, density and pressure | Omer | CFX | 9 | June 28, 2007 04:13 |
PhD using CFX | Rui | CFX | 9 | May 28, 2007 05:59 |
CFX 4.4 installation problem | Pandu Sattvika | CFX | 1 | December 1, 2001 04:07 |
