convergent_divergent nozzle simulation in CFX-11
Old   March 20, 2009, 05:21
Default convergent_divergent nozzle simulation in CFX-11
sivaramakrishnaiah
sivarama1 is on a distinguished road
Send a message via MSN to sivarama1 Send a message via Yahoo to sivarama1 Send a message via Skype™ to sivarama1
hi,
1) In CFX-11,Two regims of flows how should analysis actually,take
convergent and divergent nozzle (in convergent is subsonic and
divergent is supersonic)
1)subsonic
2)supersonic
in two region in single model (that means convergent and divergent
nozzle in a single geometry in that in that i will give boundary
condition inlet of convergent pressure 15 bar steam, throat of
pressure 8 bar outlet of 1 bar pressure)
i know inlet velocity of steam 856 m/s this is saturation steam.
How will analysis in CFX-11,as a hypercritical point of correct
results came,but i should verified in CFX-11 SOFTWARE analysis,please
let me know.
once again thankyou for replay.
Actually i done same process,but solution not converging
Geometry:combined of convergent and divergent nozzle.
Converging and diverging nozzle flow problem
My doubt,this model i was created in UNIGRAPHICS modeling
software,meshing ICEM CFD,
when ever i am giving analysis:at that time some problem is there
step2:Boundary condition
Fluid :Steam
mass flow rate:0.5 kg/s
at inlet of convergent nozzle:subsonic condition a)pressure=10
bar;Temperature:356 m/s
at outlet of Divergent nozzle :a)supersonic condition .
You told this type of settings and simulations given by tutorial 8
from ANSYS CFX release 11.0. in this different : inlet is supersonic
condition outlet also supersonic condition
but my point of view inlet is subsonic and outlet is supersonic condition
sivaramakrihnaiah
sivarama1 is offline   Reply With Quote
Old   September 24, 2009, 09:43
Default B.C at the nozzle for simulation CFX 11.0
Sudharshani
Sudharshani is on a distinguished road
hai could u pls let know
how did u set up the B.C at different conditions(from subsonic.sonic.supersonic and
after that catching the expansion and oblique shock waves after exiting the divergent section of the nozzle.
as we know the at the exit of the divergent section of the nozzle the pressure condition will be atmospheric so, to capture anything happening in this section do i need to used another B.C
as i assume at this stage alltogerther there will be pressure inlet, pressure outlet and something.......at the jet plume region..
could u explain...i am bit confused.
thanking
sudharshani
Sudharshani is offline   Reply With Quote
Old   September 25, 2009, 00:52
Default nozzle
sivaramakrishnaiah
Hi sudharshani,
i was taken in UDF in that i wrote some program .
i should send file,tell me your mail ID.
Regards
Sivaramakrishnaiah
from india.
sivaramakrihnaiah
Old   September 25, 2009, 03:31
Default mail ID
Sudharshani
sudharshani07@hotmail.com
Old   October 1, 2009, 07:03
Default C-D Nozzle
Jwala
Jwala.R is on a distinguished road
Same analysis was done using star cd using afterburner (component of military engine) and c-d nozzle
In your case you can define subsonic inlet condition , stagnation temperature and Stagnation pressure at inlet and static pressure at exit of nozzle ie. at the end of divergent duct so that you can see the stable oblique shocks in the divergent section.In unsteady case you can have unstable shocks in convergent section too.
with Regards.
Jwala.R is offline   Reply With Quote
Old   October 9, 2009, 00:47
Default supersonic CD nozzle
Sudharshani
hai..jwala R
Thanks for that.....but CFX-Pre 11.0 i couldn't see Stagnation pressure as a icon under inlet condition.
it had only two options : Static Pressure and Total pressure (stable)
anyhow....if i set static pressure as 7atm-8atm and left outlet as.. "Opening" BC then how do u generate supersonic flow......
by reducing the outlet pressure to 1atm(which should match the ambient pressure).....would i be able to get smooth(ideally) uniform supersonic flow at exit of my nozzle....?
could u help.....pls
thanks...so much
sudharshani
Old   October 9, 2009, 00:58
Default NPR Vs cross section area of supersonic nozzle
Sudharshani
hai.....
i would like to know NPR (for supersonic nozzle is somewhere between 7:1 or 8:1) depends on the nozzle geometry( area ratio: exit/throat and inlet/throat)?
sudharshani
Old   October 9, 2009, 01:07
Default Hi
Jwala
Total pressure (stable) can be given as inlet boundary condition.
And Static pressure as the outlet boundary condition.
Generally you need to give the ambient pressure at the outlet .
That depends upon at what height the nozzle is working.
Is it at sea level static condition or the distance above the sea level
If it is at sea level static condition then you need to see the atmospheric condition of the place.
It will differ for a place like africa and canada.
Regards,
Jwala
Old   October 9, 2009, 10:27
Sudharshani
Hai...
thanks for that...i will try that.
in the mean time i would like to see whats happening at the jet plume area of the nozzle exit( to c how the expansion +oblique shocks are being created)....etc
how do i set the boundary condition of the exit of the nozzle as it will also be the (kind of the inlet )of the jet plume section..?
iam using CFX-mesh11.0....so how would i set up
my model contain two sections: (using ANSYS WB i drew two sketches)
(1)sketch1(convergent part+divergent part)
(2)sketch 2(jet plume region)
as the whole section is extruded in Z diection , i cannot select the outlet on my model(as a "opening" B.C) in CFX Mesh for labeling the regions..
i hope u understood the question....some help would a very much appreciated.
thank u
sudharshani
Old   October 12, 2009, 08:31
Default Convergent-divergent nozzle
sivaramakrishnaiah
HI JAWALA AND SUDARSHANI,
I am also simulating convergent and divergent nozzle,
My problam convergent is subsonic condition and throat sonic,divergent supersonic condition.
inlet pressure 15bar
saturation steam Temperature at 198 C,
outlet pressure1.5bar,
inlet velocity:32 m/s
i am simulating 2D model,i given boundary conditions same above mention,,
My doubt is two regions is there(subsonic and supersonic) is not taking in CFX solver,what i will do .how to give boundary conditions as per this solution.
My GEOMETRY I AM ATTACHING .IGS FORMAT IN the given link:
http://www.4shared.com/file/14031536...76/nozzle.html
Thanks.
sivaramakrihnaiah
Old   October 12, 2009, 22:46
Default Hi
  #11
Jwala
Hi Sudarsini.
Have you extended your nozzle?
Outlet should be around 6R to 7R from the actual nozzle exit.
R is the Nozzle inlet Radius.
Similarly you need to extend it vertically to 4R.
Siva you can specify Either Total stagnation pressure or velocity based on 1D caculation for compressible flow.
Regards,
Jwala
Old   October 12, 2009, 23:12
Default converging-diverging nozzle
  #12
sivaramakrishnaiah
Good afternoon ,
in that CFX,and ICEM files.
Fluid :Steam
sivaramakrihnaiah
Old   October 12, 2009, 23:33
Jwala
Assuming the BC'S implied is correct and according to your requirement,Check for Y+ and timestep. What is the error or problemy you faced during simulation?
Regards,
Jwala
Old   October 12, 2009, 23:45
  #14
sivaramakrishnaiah
Hi jawala,
In cfx-11,i given boundary conditions:inlet:total pressure and total temperature with subsonic condition,i want to give out let supersonic,but it showing only subsonic.
whats problam.
please give me your MSN messanger or google talk ID,i should contact.
sivaramakrihnaiah
Old   October 12, 2009, 23:51
Jwala
Hi.
You are getting subsonic condition at outlet.Assuming your solution is converged
Actually I am not able to open the link sent by you.
What is the outlet static pressure specified and what is ratio of Eit area/Throat area .are you geeting flow choked at throat or sonic condition.
Meanwhile i will try to open the link.
Regards,
Jwala.
Old   October 12, 2009, 23:58
  #16
sivaramakrishnaiah
exit area/inlet area=0.5947,
outlet static pressure=1.5bar,inlet total pressure=15 bar, total temperature=198 CALTERNATIVE_GEOMETRICAL_MODEL.jpg
sivaramakrihnaiah
Old   October 13, 2009, 00:02
  #17
sivaramakrishnaiah
INLET DIAMETER:50.8mm,
outlet diameter:27.7mm
throt diamter:17.7 mm
inlet pressure=15 abr,outlet pressure:1.5bar,inlet velocity=32m/s,inlet temperature:198 C
sivaramakrihnaiah
Old   October 13, 2009, 01:51
Default Transient analysis
  #18
mistry
csmistry is on a distinguished road
friends i am also doing analysis of CD nozzle and to have transient flow analysis:
for steady state
i have:
wokng fluid: ideal air
inlet pressure:1 bar
outlet pressure=0.98,096.,90,.94...... i want to visulise effect of critical pressure ratio tat is at 0.56 but unfortunately i am unable to catch shock...
secondly i want to do transient analysis for hthat inlet is same but outlet pressure i assume = p*sinwt. where t i want to vary from 0 to 20 sec. but haw to put this effect....
pleaase do guide me
csmistry is offline   Reply With Quote
Old   October 13, 2009, 19:31
Default Inlet outlet BC, characteristic length
  #19
Sudharshani
hai....guys....
yes...i extended the nozzle additional area as a opening BC to cature the jet plume region.
my questions are
(1) how do u know ur Inlet velocity?..... did u get these figures like mass flow rate from any experimental data....?(to my undestanding if a nozzle is operating at 60,000ft then the speed of sound(0.8596m/s) temp(-62C/216K) and ambient pressure(0.043atm) will also be different...isn't it?...i used these
figures ,but didn't give mass flow rate.....only static pressure value for inlet....do u think its correct?
(2) i saw the dimentions u have given,but by my nozzle shape is different.....its cross section is rectangular and is not axsymmetic.....here with i will add for u to see how it looks....(the bigger squre and the curved section is for the jet plume region).....is ur NPR is 15:1?
(3)Which turbulence model are u planing /or have used.....? when calculating k-e model to calculate k,e what is the characteristic length did u use?
is it the cross section of the nozzle or the lengh of the total nozzle?
(4) how did u set outlet BC as supersonic.....iam using CFX 11.0 version (not sure about the 12.0 ver)....it will not allow me ?
i set Ideal real Gas(not air at 25C) assuming it will aloow me to set5 supersonic at outlet..but didn't)
outlet static pressure=1.5bar,inlet total pressure=15 bar, total temperature=198 CAttachment 1245
Old   February 18, 2013, 03:05
Sami
abdul Sami is on a distinguished road
Plz tell me the terms, static pressure, total pressure, static temperature and total temperature with respect to convergent divergent nozzle I m so worried plzz help me I will be thankful
abdul Sami is offline   Reply With Quote
Pros and Cons for CFX, CFdesign, COMSOL Val Main CFD Forum 3 June 10, 2011 02:20
nucleate boiling simulation in CFX Anil CFX 3 August 25, 2010 14:18
Simulation of turbine cascade in CFX. Jonas Pedro Caumo CFX 0 December 9, 2006 13:54
mesh from Workbench Simulation to Cfx Pre? Dai CFX 6 November 11, 2006 12:19
Help for simulation of a laval nozzle Ho CFX 1 September 27, 2005 18:25
