How to simulate a plane with propeller
Old   March 23, 2009, 03:15
Default How to simulate a plane with propeller
Lukasz
Luk_Fiz is on a distinguished road
Hi all,
I have following problem.
Simulating a propeller (or fan) we usually use "circular" symmetry: we model the flow domain around single blade and after that use symmetry on both sides. We apply rotation and so on... and achieve fan specifications.
But what to do in case of for example plane or hovercraft that also has a propeller but has no circular symmetry in the rest of the construction (a hull, wings)? Is it possible to simplyfy calculation in CFX using some symmetry criteria or to calculate in steps, for example a propeller at first and after that using momentum source for the rest of the plane?
I would be very grateful for any suggestions,
Luk
Luk_Fiz is offline   Reply With Quote
Old   March 23, 2009, 22:44
In this case we use multiple domains. One domain is a rotating frame of reference and the other is stationary, and they are connected with a GGI (the general domain interface).
Regards,
Old   March 24, 2009, 03:34
Lukasz
Hi Glenn, thanks for Your reply but it is not exactly my point. I know that the domains should be connected by interface (as it is also with propellers if You want to simulate some far "inlet" or "outlet"). But in case of simulating only properller You are able to use "circular" symmetry what dramatically reduces the mesh, time consuption and so on... My question is: are similar things possible with simulation of the for example propeller and the plane hull that has no circular simmetry.
For example, simulating plane with propeller in the nose: can I simulate half of the hull (symmetry BC in plane along the hull) and a single blade of propeller (defined as rotating domain) with circular simmetry.
Simulation of full plane will be very demanding for hardware - entire hull and a multiblade propeller (rotating domain).
Luk
Old   March 24, 2009, 16:13
Yes, you can use symmetry and periodicity and combine with multiple frames of reference. You can do this with the frozen rotor or stage averaging approach.
Old   March 25, 2009, 03:04
Lukasz
Niiiiice!!!
Thanks You very much!
Luk
[Gmsh] Problem with Gmsh nishant_hull OpenFOAM Meshing & Mesh Conversion 23 August 5, 2015 02:09
ICEM and symmetry plane Roland CFX 3 September 13, 2006 08:38
simulate a tank equipped with propeller inside aloha5i CFX 0 October 15, 2005 15:56
Boundary zones in Gambit for a 3D propeller. Craig Paxton FLUENT 1 June 10, 2002 12:57
Mixing plane geometry definition Hbet FLUENT 0 January 18, 2002 07:16
