BC in closed box simulation
Old   March 30, 2009, 19:58
Default BC in closed box simulation
Miguel Baritto
Miky1020 is on a distinguished road
I am simulating free convection inside a closed box. I have set heat flux at the bottom and insulated walls at the others surfaces. Also, I have set no slip at all the surfaces. However, I have problems with convergence and I think (after read cfx documentation) they are in BCs, since I haven't set pressure nor temperature levels at any BC. Could this be true? if so, how can I set pressure and temperature in a closed and insulated box?
Thanks
Miguel
Miky1020 is offline   Reply With Quote
Old   March 31, 2009, 17:55
I assume you are running a transient simulation - it has to be as you have a hot wall on the bottom and everything else adiabatic so it is going to heat up over time. These type of buoyancy simulations invariably have big transient flow instabilities. You often have to run much smaller timesteps than you would expect to resolve these transient features.
Just set the reference pressure and temperature at the initial temp and pressure, that should be OK.
Old   March 31, 2009, 20:16
Miguel Baritto
Thanks Glenn,
I will try smaller timesteps.
simulation two phase closed thermosyphon mohammad reza FLUENT 3 November 1, 2016 03:58
Immersol Simulation of a Heated Box Dong Phoenics 0 March 2, 2006 21:20
heat tran simulation two phase closed thermosyphon mohammad reza CFX 1 February 28, 2004 00:48
Fire simulation using FDS from NIST Jens Main CFD Forum 1 January 22, 2004 01:53
3-D Contaminant Dispersal Simulation Apple L S Chan Main CFD Forum 1 December 23, 1998 10:06
