MODELING A ROTATING BLADE(pleas hehlp)
Old   April 13, 2009, 01:48
Question MODELING A ROTATING BLADE(pleas hehlp)
hmasenger's Avatar
hamed
hmasenger is on a distinguished road
HI THERE
is there any need to model the blade and the atmosphere together for analysing the act of TRANSMITTAL of material of atmosphere affected by the blade?!
if yes should i define a solid domain for the blade and a fluid for the atmosphere?
so how can i define the rotation of blade? i cant define rotation in solid domain?!!!
hmasenger is offline   Reply With Quote
Old   April 13, 2009, 09:10
Fritzl
k_buz is on a distinguished road
You actually only need the fluiddomain where the blade is cut off. So in the middle of the domain the shape of the blade is missing. then you put a boundary condition "wall" to that boundary. then you can set up the domain as a rotating domain. so you actually let rotate the domain instead of the blade..
check out that post: http://www.cfd-online.com/Forums/cfx...ultifield.html
k_buz is offline   Reply With Quote
Old   April 13, 2009, 15:05
Default tanks alot
hmasenger's Avatar
hamed
i really appreciate
your favor
u got the problem right.
tanks alot
IcoDyMFoam how to define more than one rotating regions naoko_oyama OpenFOAM Running, Solving & CFD 0 November 14, 2008 08:25
modeling two liquids flow over a rotating disk fadhil FLUENT 3 May 20, 2008 05:19
FSI on a Rotating Structural Model drgolf CFX 9 August 30, 2007 12:08
Difference b/t rotating wall and rotating domain? Juno Kim CFX 2 February 20, 2007 20:08
Modeling Flow/Saturation/Absorption in Fibers Gene Dougherty Main CFD Forum 0 June 6, 2003 14:49
