CFX simulate boiling&condensation simultaneously?
Like Tree1Likes
  • 1 Post By Neale
Old   August 9, 2005, 23:52
Default CFX simulate boiling&condensation simultaneously?
whiz
Can CFX simulate boiling and condensation simultaneously? For example, a closed box, contains about half box of water at first, then heats the bottom and cool the top. Water will get boiling, and water stream will condense at the top wall. Can CFX simulate this complicated phenomena? If so, please send me some related information.
Best Regards,
whiz
Old   August 10, 2005, 22:27
Default Re: can somebody help me?
whiz
none
Old   August 25, 2005, 23:54
Default Re: CFX simulate boiling&condensation simultaneous
Neale
Yes. Try the inhomogeneous multiphase + thermal phase change. It can be done but you will need CPU time, mesh resolution and patience.
Old   September 5, 2005, 02:39
whiz
Dear Neale, I found that if simulate boiling, the water is treated as continuous fluid, and the water vapour as dispersed fluid. But to simulate condensation, the water is treated as dispersed fluid, and the water vapour as continuous fluid. Am I right?
If boiling and condensation can be calculated simultaneously, how to set the heat transfer model between the two fluid (water and water vapour)?
Are the all continous fluid? How to set the it?
Bow
with best Regards,
whiz
Old   September 19, 2005, 04:25
Vijay
Try creating two domains and modelling them seperately. The lower domain can be a water continuoul domain and the upper as a vapour continuous domain.
Try this
Old   September 19, 2005, 21:57
Neale
Welcome to the world of multiphase modelling. What you are doing is not easy. You will always need to run with:
- inhomogenous heat transfer - thermal phase change model - two resistance heat transfer option.
If your flow regime does not fall into the classical continuous-disperse category then you may not be able to use any of the continuous-disperse heat transfer relationships (eg: Ranz Marshall).
You will have to play around with one of the other options (eg two heat transfer coefficients, two Nusselt numbers, etc..) until you get something that looks sensible. It will depend on your flow regime: small bubbles, large bubbles, bubbles, slugging, etc...
Neale.
wwjshirley likes this.
Old   December 7, 2012, 01:27
sharon
sharonbashyam is on a distinguished road
neale thank you......
sharonbashyam is offline   Reply With Quote
[stressAnalysis] How to simulate thermal stress and heat transfer simultaneously using OF? masb OpenFOAM CC Toolkits for Fluid-Structure Interaction 18 July 20, 2015 22:24
Pros and Cons for CFX, CFdesign, COMSOL Val Main CFD Forum 3 June 10, 2011 02:20
Electronics Enclosure Analysis with CFX Simulation Engineer CFX 1 April 22, 2009 11:08
Importing solutions in CFX. Alphonso CFX 1 August 1, 2008 14:01
CFX 10 in CFX 5.7 panneerselvam.R CFX 6 February 6, 2006 03:56
