cfx solver
Old   May 1, 2009, 02:52
Default cfx solver
uk jha
u k jha is on a distinguished road
hi ,
thanks triton,
i am solving the same problem i created the turbomachinery mesh in two parts. one is casing(stator) and rotor(impeller) and i gave almost all the inputs in the cfx pre but solver stops after one iteration or it does not start.
i am no able to give interface between stator and rotor.
thanks
u k jha is offline   Reply With Quote
Old   May 1, 2009, 12:22
Amit Roghelia
Amit Roghs is on a distinguished road
You should use Frozen Rotor if you have chances of mixed or radial flow.
And if you have axial flow then you should use Stage.
Amit Roghs is offline   Reply With Quote
divergence in CFX solver Tanveer Ahmad Rubani CFX 1 February 24, 2009 16:19
mach number and CFX 11.0 solver turbinesv CFX 5 January 5, 2009 05:43
CFX 11 Solver problem dak56 CFX 3 December 11, 2008 19:20
CFX Solver to run 10 files sequentially Raj CFX 8 October 29, 2008 22:20
problem in CFX solver about isolated volumes Yuan CFX 2 August 16, 2004 22:54
