Heat Transfer - Intersection Fluid-Solid
Old   April 30, 2009, 04:03
Default Heat Transfer - Intersection Fluid-Solid
Alder
Alexandre is on a distinguished road
Hi all,
I do some simulation for an axial turbine, where I want to find out the temperature distribution in the blade (conjugate heat transfer). So I have two domains, the fluid (sturctured grid) and the solid (have to make the grid). For the heat transfer from the fluid to the solid, on the intersection, do the nodes of each domain have to lie exactly on each other? Or will the results be accurate if I use an unstructured mesh for the blade without worrying about the location of the nodes?
Thank you for the answer,
alexandre
Alexandre is offline   Reply With Quote
Old   May 1, 2009, 22:52
stumpy is on a distinguished road
Unstructured mesh is fine. Just use a similar mesh length scale on both sides.
stumpy is offline   Reply With Quote
radiation transfer between solid and fluid zone shyang FLUENT 0 August 13, 2008 12:45
Heat transfer trough a solid domain Tiago CFX 2 March 17, 2008 14:54
modeling heat transfer betwwen fluid and solid Al Mazdeh CFX 0 March 13, 2008 10:35
Water vapour condensation in CFX-5.7.1 hdj CFX 1 November 27, 2005 07:15
CFX4.3 -build analysis form Chie Min CFX 5 July 12, 2001 23:19
